05-26-2009 11:55 AM - edited 03-11-2019 08:36 AM
I have a need to sort and view current connections and examine the "uptime" component of each connection.
For example, if one issues the command, "sh conn long" one can get the uptime value, like " uptime 11D13h."
I need to examine this traffic and examine the conns with the long uptimes. However, the ASA (7.2) does not appear to offer an option for sorting based on real time.
I've never been a coder, scripter, hacker, so if there is some way to use excel to convert "uptime 11D13h" and "uptime 1m46s" into their appropriate values so it can be accurately sorted, that would be good.
Any ideas.
05-27-2009 09:54 AM
Presently there is no way to get that sh conn long output sorted to display the longest to the shortest.
05-27-2009 12:52 PM
Thanks.
Wow, I doubt I am the only one whom has wanted to audit connections.... and take into account connection time length.
Is there some way to request features for Cisco Products outside of going to our account team? Has Cisco embraced a feature request system like that which is used to track, develope, and deploy feature requests as in the open source community.
At least if something is tracked with some way to track it I know it will not go into some unknown place to which I never get a response or status update of.
05-27-2009 05:15 PM
I am working on that. I can file an enhancement request for this so a "sort" keyword gets added in the future release.
Pls. contact your local Cisco account team and indicate to them how critical this feature is for your enterprise. They will in turn get in touch with the business unit and will be able to drive the enhancement request further.
05-27-2009 06:35 PM
Here is the enhancement defect ID CSCsz86509
You can view it here:
05-28-2009 04:53 AM
Logged into my CCO account, I cannot view that CSC.
I did not know that Cisco even documented feature requests. Like I've said before, I do not believe I've received feedback or confirmation of feature requests.
07-18-2011 06:46 AM
Any progress on this feature enhancement?
05-28-2009 04:50 AM
Thanks for your initiative with this.
At the least, it would be extremely helpful if Cisco would migrate away from the "11D13h" format for time representation or offer a command option to convert it. I would honestly suspect that Cisco's firewall software really keeps track of this info in milliseconds, not in DHMS.
I can not figure out how to sort it correctly after I've imported into excel. Excel sorts it something like this...
10d
10h
10m
10s
11d
11h
11m
11s
So, the hour long connections are grouped with the seconds long connection and such. When one has 6 thousand lines, cutting through this visually does not scale. And like I said before, I'm not a much of a scripter. I'm sure to some skilled scripters, changing 11h30m into seconds on thousands of lines is a 5 minute development task. For myself, it would be much longer chore.
