Connectivity Issue
Dears,
I have a  Cisco PIX-525 centering my network and connecting 5 DMZs in addition to the Inside and Outside Zones. recently there is a complain from one of Portal Admins claiming that there is a diconnectivity that happenes daily (many time throughout the day) between WAP-Portal Server (DMZ1) and DB Server (Inside). i tried monitoring the logs on PIX and they are only showing connections being built and torn down, Packet Tracer shows that the packets are allowed in both sides, however, their argument is that when monitoring Wireshark on both the destination and the source, the packets appear on the source however they are not received on the  destination.
is there any settings on the PIX to check if there are any dropped packets (might be because of utilization or something else)? and are there any global settings that might cause sessions to time out?
Hussein
Re: Connectivity Issue
apply captures on the firewall ingresss and egress interface nd see if the firewall is dropping it
138
