Console screen for ASA showing too many messages?
I have ASA 5520 and when I log into the CLI there is a constant filter of logs coming in, so many I can do anything. What do I need to stop these and maybe jsut show critical issues and not rules being triggered etc?
Gold
Re: Console screen for ASA showing too many messages?
It looks loggs is set up to be sent to you ssh/telnet session..
you can turn it off by command
no logging monitor
You can do same for console (if its on)
no logging console
Remember its still useful to have some logs send to syslog server or to buffer
Consult this page for more information
http://www.cisco.com/en/US/docs/security/asa/asa70/system/message/logconf.html
Hope that helps rate if it does
M.
If you are logging via console (serial) then you can either adjust the logging level for console:
logging console 3 or 4
OR turn it off altogether.
no logging console
If you telnet/ssh into the box then its:
logging monitor ...
and to turn it off/on temporarily you can use:
terminal no monitor
terminal monitor
Farrukh
8053
