Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
copy running config to tftp
          I'm trying to copy the running config file from an asa to a text file using tftp and it copies but when the command completes it says cryptochecksum followed by numbers and letters. I open the text file and alot of it is scrambled and doesnt look like it should. How can I fix this? Thanks.
ASA# copy running-config tftp:
Source filename [running-config]?
Address or name of remote host []? 192.168.15.5
Destination filename [running-config]?
Cryptochecksum: <numbers and letters>
4300 bytes copied in 0.7 secs
ASA#
Everyone's tags (1)
1 ACCEPTED SOLUTION
Super Bronze
Atleast for some some configurations posted here on the Cisco Support Community are not formated correctly when I open them with Notepad
I then open them with Wordpad or Notepadd++ and they show up just normally
You could try to right mouse click on the file on your computer and open it with some other application rather than the default one.
Otherwise I usually see the whole ASA configuration combined into basically continuous string of text.
- Jouni
1 REPLY
Super Bronze
- Jouni
166
