Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
CRC errors at PIX interface
HI ,
I have a PIX 535 connected through OFC to Cisco 2960 Switch.
PIX end - G0 (SC type Connector) - Switch End - Gi1/0/28 (LC type connector)
When I am pinging from either side, I am getting packet drops.  CRC error is increasing at PIX interface.
Speed settings, tried with
auto - auto
auto - nonegotiate
nonegotiate - auto
nonegotiate - nonegotiate
But no improvements.
When its connected with SC - SC connector, its working fine.
Switch also working fine when connected LC - LC.
Switch OS is 15.x  version.
Cisco PIX Security Appliance Software Version 7.0(4) <system>
Device Manager Version 5.0(4) Cisco PIX Security Appliance Software Version 7.0(4) <system>
What could be the problem, and is there any work around available?
Everyone's tags (4)
1 REPLY
Hi Lenin,
If you haven't already, I would recommend swapping the cables and SFPs with known good ones to rule out any issues there. Auto/auto speed and duplex settings are usually the best way to go if you control both sides of the connection.
-Mike
566
