CRC errors on outside interface
I've noticed a large amt of CRC errors on the outside int of a Pix 515e. We have replaced the cable but the errors are still accumulating; about 48k in the last 24 hours. Bad interface card, do you think?
1 ACCEPTED SOLUTION
Re: CRC errors on outside interface
Check the duplex/speed settings on both side of the connections.
This link might help, could rule out config issues if nothing else...
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml#showinterface
Thanks, that was it. I reset the int to auto. Funny thing is that it can't be done thru PDM if failover is enabled. I had to do it thru cli.
127
