CSM 3.1.1 Deployment problem
i have CSM 3.1.1 , the problem is when i want to deploy any changes on any device , simply i choose the device check box , & click "deploy", but the status bar doesn't move ( 0 %) , i restarted the server many times with no help
Re: CSM 3.1.1 Deployment problem
David,
Did you find a resolution to this as I'm frequently experiencing the same issue.
All the best,
Andy
hi
did you submit first the chsnges?
thanks,
Many thanks, yes I did submit the changes first.
I push the policies with 'Submit and deploy' - I'll try doing this as two seperate actions and see if it helps.
It's a very sporadic issue.
All the best,
Andy
115
