Decommision and repurpose ASA 5505
We have reconfigured our network and have decommissioned a few ASA 5505s.  I would like to allow these devices to be repurposed but do not want to allow any other business units to be able to recover and access our configuration information.  I have already done a write erase and have removed log directories.  What other steps do I need to take to clean them up while still allowing them to be fully functional?  The units do not have additional licensing (no extra users, no sec plus) but I am seeing conflicting information about what would need to be done to them if I formatted flash.
Thank you
Everyone's tags (3)
VIP Green
Re: Decommision and repurpose ASA 5505
You don't need to do anything else.  Another way of doing something similar is to use the config factory-default command.  This will set it back to the factory default settings and set the dhcp config so a user can connect and get an IP.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/start.html#wp1053752
please rate any helpful posts.
Please remember to rate and select a correct answer
Is it possible to recover any information from the device after a write erase?  The way I look at it, it is flash memory.  If I can recover photos deleted from a flash card I would think it would be simple enough to recover files deleted from flash with a simple write erase.  Is this not correct?
VIP Green
No once you delete the configuration it is gone.
126
