Default Connection timeout
I don't find the info about what are the defaul connection parameters for ASA 8.0 or above when you don't define any Class-map. So For default connection which are the default value like:
Max TCP/UDP connection & Timeouts
Max Embryonic Conn & Timeouts
Max per Client Conn & Timeouts
etc ..
There is CLI command that can I use to diplay the amount of time that is left for timeout here above or to check for a specific connection the parametrisation ?
Re: Default Connection timeout
This model comparison table may answer some of your questions:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hello, I'm thinking connection setting related to CLI command "set connection" where we can define Max connection and embryonic connection. In particular defaul value for traffic that has no Class associated.
179
