Bronze
Default Route not appearing on ASA
Hi All,
I have configured an ASA 5512 - and simply trying to add a default router out my Outside Interface.
route outside 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX
However, when I do a show route, it is not there. Only my directly connected networks show from my Subints.
Is there something that would stop my default route from showing?
2 ACCEPTED SOLUTIONS
Super Bronze
Can't say I have ever run into this problem.
If this ASA is a new/fresh setup then have you made sure that the "outside" interface is UP? That it has connectivity and is not still configured with "shutdown" command. This would be one reason that the route would not show up with the "show route" command.
Does the command "show run route" list the default route in the configuration though?
- Jouni
Hi Grant
I think the physical interface is shut thats why you are not able to see the rotue associated with that interface.
Please collect the following outputs:
sh int ip b
sh run route
sh route
Cheers,
Naveen
Super Bronze
- Jouni
Bronze
I do apologise....in my rush getting this tested I had not even plugged in the Outside Interface yet. Was too busy focusing on my Lan side!!! oops.
Super Bronze
Glad to hear it got sorted out.
Please remember to mark a reply as the correct answer if it answered your question.
- Jouni
Hi Grant
sh int ip b
sh run route
sh route
Cheers,
Naveen
116
