Deny TCP No connection from inside to outside
Hi Everyone,
Client PC is accessing the server .
Below are logs from firewall
Jan 30 2014 20:47:04: %ASA-6-302014: Teardown TCP connection 1005516219 for RC:172.23.35.102/45758 to XNet:172.25.27.8/2002 duration 0:00:00 bytes 5435 TCP FINs
Jan 30 2014 20:47:04: %ASA-6-302013: Built inbound TCP connection 1005516229 for RC:172.23.35.102/45759 (172.23.35.102/45759) to XNet:172.25.27.8/2002 (172.25.27.8/2002)
Jan 30 2014 20:47:04: %ASA-6-106015: Deny TCP (no connection) from 172.23.35.102/45758 to 172.25.27.8/2002 flags ACK on interface RC
Does this mean that client PC send TCP syn to server and before server reply with SYN,ACK the Client again send the SYN towards the server and ASA
receive the ACK on interface RC  from the client?
MAhesh
  • Firewalling
3 ACCEPTED SOLUTIONS
Hello Mahesh,
No, This means that the connection was closed and afterwards the client try to access the server over the same connection so the Firewall will refuse that.
There is a sysopt command to reduce the time  where the ASA refuses packets over the same traffic flow/connection that was previously closed (Default time is 15 seconds)
Command is
sysopt connection timewait #
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Super Bronze
Re: Deny TCP No connection from inside to outside
Hi Mahesh,
Notice the source port of the connection.
The first log message clearly indicates that this connection was normally torn down on the firewall because it saw the normal closing sequence of the TCP Connection (TCP FINs)
The next message is the host forming a new connection (notice again the different source port). This is not related to the other 2 messages.
The final log message seems to indicate that there is a packet for the previous connection that was already tore down by the ASA. To my understanding the ASA should teardown the connection if it has seen the normal closing sequence. So that makes me wonder why the client would still be sending TCP ACK. Unless it still somehow related to the connection termination.
The Client should not send anything to the server after the TCP SYN (other than new TCP SYN) if it never received the TCP ACK (and SYN = TCP SYN ACK) from the server to acknowledge that the server has received the clients initial TCP SYN. The client will simply send a few TCP SYN at certain intervals until the connection attempt timeouts if it never receives the TCP SYN ACK from the server.
Naturally a traffic capture would tell much more if there is some problems with the connecitivity and you want to take a closer look.
- Jouni
Hello Mahesh,
My pleasure to answer them:
Client sends SYN to the server right?
Yes, the server innitiates the TCP connection.
Client does not receive SYN,ACK from the server right?
I would need to see the entire flow as what is shown by you is after the connection is torn-down but apparently the session was built so yes.
Firewall closes the connection and just after that
Client sends ACK to the ASA right?
The firewall is not the one closing the session, actually both ends agree to close it using the Graceful Termination TCP packets or FIN.
The ASA as saw that the connection was closed by each of the client removes it from the conn table so it should NOT receive any other packet from that specific session.
There are some applications that will use the same traffic flow for a new session after has been closed and this causes issues with Firewalls.
Does it mean that if client does not receive syn,ack from the server within 15 secs it still sends ACK to the Server?
is this default behaviour?
No, again it means that the connection was closed and the asa inmediatly receive a packet for the connection that was closed-.
Cheers,
Hello Mahesh,
Command is
Cheers,
Hi Julio,
I am trying to understand the traffic flow here.
So initally  Client send syn to the server and traffic goes via ASA.
Then server sends SYN,ACK back to the Client.
Then client send final ACK to the server.
But in this case if you can answer the few questions below please ----
Mahesh
Super Bronze
Hi Mahesh,
- Jouni
Hello Mahesh,
Cheers,
Hi Jouni & Julio,
Seems issue was routing.
Thanks for explaining we in detail.
MAhesh
705
