Hi Ibrahim,
The ASA is just reporting that you are receiving a packet on an interface where it shouldn't be received, based on the routing table.
So if 172.16.38.114 is on your Inside it is expected for the ASA to display that message if you are getting a pcket with that source IP address on the Outside interface.
You would need to troubleshoot here why those packets are being received on the Outside in the first place. You can set some captures on the ASA Outside interface and then check the source MAC address in the packet in order to have a clue about from what kind of device you are receiving those packets.
If troubleshooting this gets complicated at the moment you can remove the following command from the ASA and you won't see those logs anymore:
ip verify reverse-path interface outside
This is the command that enables the RPF check on the ASA.
I hope it helps!
