Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
determining current E# of connections before applying limits
Where do you pull statistics on the ASA to determine my current teraffic patterns to a DMZ server so I can estimate reasonable values for connection limits?
1 REPLY
Re: determining current E# of connections before applying limits
Issue :
sh conn | in x.x.x.x
x.x.x.x--> ip of server
It would give you all the existing connections made to the server.
Issue this several times at different times in a day to find out the meximum connections made to the server.That number can be used as the meximum limit....
Do rate if helpful.
Sushil
114
