Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
DHCP-RELAY with interface dedicated servers
Hi, in ASA with dhcp-relay mode, is there a solution to obtain a different dhcp server for each vlan ?
thanks
rs
Everyone's tags (2)
Re: DHCP-RELAY with interface dedicated servers
Here is what is supported on DHCP Relay on ASA:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/dhcp.html#wp1115812
You can not define each interface pair for DHCP client request interface and DHCP server relay interface.
Community Member
Thank you, but I need to associate a different dhcp server pool for each ASA vlan, through ASA dhcp relay.
From the configuration doc, it seems that I cannot associate a pool of dhcp server to a single vlan, so the dhcp server pool created are generally configured for all vlan with active dhcp relay.
rs
Yes you are absolutely right. You can't configure specific dhcp server for a specific client request for DHCP relay feature on ASA.
369
