difference ASA5510-BUN-K9 and ASA5510-Sec-Bun-K9
ASA 5510 have two model Bun-K9 and Sec-Bun-K9
from the datasheet find out difference Port related and Redundancy.
My questions is : Have any major difference for Security service between two model ??.
Iqbal
Everyone's tags (1)
Red
Hi Iqbal,
as you can see the difference in the datasheet, there is a difference of license on the two. In ASA5510-Sec-Bun-K9, you have the failover license along with the license for 2 gigabitethernet ports.
If you are asking hardware wise, they both are the same. Its just a difference of license features on the two.
If you do not want failover license and the gig ports you can go for ASA5510-Sec-K9, its the same.
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
HI Varun
Thanks for your prompt response.
But many times client asks as ASA5510-Bun-K9  not mentioned SEC so any lagging for security feature without failover& Port License. so what will answer of us ??
iqbal
Red
Hi Iqbal,
No there are no lagging security features in ASA5510-Bun-K9, the only two things that you would not have is:
No failover between two firewalls possible
No gig port available for high speed data transfer
Except these two there are no security lagging in it.
If the client doesnt want these, then you can purchase ASA5510-Bun-K9.
Varun Rao
Security Team,
Cisco TAC
2029
