Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Difference between static nat & alias?
Hi guys,
what is the difference between static nat & alias?
is it that in alias ip addresses can be in any interface?
just i cant no understand when to use alias command? and why?
1 REPLY
Re: Difference between static nat & alias?
According to the 7.0 command reference, Cisco no longer recommends using the alias command:
"To manually translate an address and perform DNS reply modification, use the alias command in global configuration mode. To remove an alias command, use the no form of this command. This command functionality has been replaced by outside NAT commands, including the nat and static commands with the dns keyword. We recommend that you use outside NAT instead of the alias command."
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/ab.html#wp1343428
371
