05-30-2012 05:25 PM - edited 03-11-2019 04:13 PM
Im wanting to setup SSL VPN Clientless. Can i select an IP address as the interface? What I have is the outside interface plus other addresses going to the same interface using arp alias to the same MAC Address as the outside interface... Why I would like to use another IP address as currently im using 443 on the outside interface.
05-30-2012 09:29 PM
Hello Dino,
That is not possible, you will need to use the ip address attached to the physical interface, not one that is being proxy-arp by the asa.
Regards.
Julio
05-30-2012 11:14 PM
Ok thanks
Dino Chirico | IT Manager
T: 03 9697 2222 | F: 03 9697 2200 | M: +61 (407) 454600
W: Prosum.com.au | E: Dino.Chirico@prosum.com.au
A: 6 Ross Street , South Melbourne 3205
Disclaimer
This message may contain confidential, proprietary or legally privileged information and is intended only for the individual named. No confidentiality or privilege is waived or lost by mistaken transmission. If you are not the named addressee you should not disseminate, distribute, copy or disclose its contents to anyone. Please notify the sender immediately by e-mail if you have received this e-mail in error and delete all copies and destroy any hard copies from your system. PABX Sales and Service Pty Ltd Trading as Prosum of 6 Ross Street South Melbourne ABN 53 087 133 702 and any of its subsidiaries each reserve the right to monitor all e-mail communications through its networks. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to state them to be the views of any such entity.
