direction of udp connection in ASA
Hello.
How can i determine direction of udp connection in ASA?
1 ACCEPTED SOLUTION
Purple
yes there are no flags but looking at the ports you know it is SNMP and port 161 is the agent port for receiving requests
so it is 44.44.44.190.211 which initiated a SNMP request to 100.74.53.18.
But you're right we can't see in the output   which initiated the connection  as there is no  flag because UDP is connectionless.
Regards.
Alain
Purple
show conn protocol udp.
Regards.
Alain
Alain, how can you determine direction for this connection?
UDP outside:44.44.190.211/36923 inside:100.74.53.18/161,  flags -, idle 3s, uptime 3s, timeout 2m0s, bytes 871
There are no flags, which show originator of connection.
Purple
Regards.
Alain
858
