Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Disable Aggressive Mode on a PIX running 6.3
How can I turn off Aggressive mode on a PIX 501 running 6.3?
This is a security issue for our PCI compliance.
1 ACCEPTED SOLUTION
Re: Disable Aggressive Mode on a PIX running 6.3
You cannot disable aggressive mode in 6.3 code. PIX would try to initiate the connection first on Main mode and if it fails would try
aggressive mode.
Syed Iftekhar Ahmed
aggressive mode.
Syed Iftekhar Ahmed
Community Member
Thank you for this information. I was afraid of that. Again thank you for your reply
John
Community Member
In what version of the code can the disabling of aggressive mode be done?
Thanks!
7.0 and higher.
"isakmp am-disable"
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/gl.html
Arul
*Pls rate if it helps*
1279
