Dispatch Unit - High Cpu Usage
ASA5510 8.2.5(50)
The Dispatch unit process is contantly having high cpu usage for last 10 hours.
Things checked:
1. show proc cpu-usage
2. show perf
    It seems fine . Output attached
3. Show interfaces for error
    No error, overruns, underrruns on interfaces
4. show traffic
    Total cumulative through put on approx 4 Mbps.
     drop rate max is 3 pkts /sec randomly and rare occurance on some interfaces
     5. Connections and Xlate seem normal.
         approx 1100.
      Counters were reset 1 hour before the data was collected.
# sh cpu usage
CPU utilization for 5 seconds = 39%; 1 minute: 38%; 5 minutes: 44%
# sh processes cpu-usage sorted
PC         Thread       5Sec     1Min     5Min   Process
081aadc4   a79aff7c    35.7%    37.5%    42.5%   Dispatch Unit
0853f89e   a79a0b68     0.4%     0.2%     0.2%   ARP Thread
# show perfmon
PERFMON STATS:                     Current      Average
Xlates                                0/s          0/s
Connections                          21/s         32/s
TCP Conns                            17/s         28/s
UDP Conns                             1/s          1/s
URL Access                            0/s          0/s
URL Server Req                        0/s          0/s
TCP Fixup                             0/s          0/s
TCP Intercept Established Conns       0/s          0/s
TCP Intercept Attempts                0/s          0/s
 sh interface e0/0 | inc overrun
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
fw01/act# sh interface e0/1 | inc overrun
# sh conn all
1135 in use, 8777 most used
# sh xlate count
112 in use, 265 most used
# show asp drop frame
  No route to host (no-route)                                                870
  Flow is denied by configured rule (acl-drop)                            103915
  First TCP packet not SYN (tcp-not-syn)                                    1317
  Bad TCP checksum (bad-tcp-cksum)                                             2
  TCP failed 3 way handshake (tcp-3whs-failed)                              6695
  TCP RST/FIN out of order (tcp-rstfin-ooo)                                 4025
  TCP packet SEQ past window (tcp-seq-past-win)                               13
  TCP Out-of-Order packet buffer full (tcp-buffer-full)                     1949
  TCP Out-of-Order packet buffer timeout (tcp-buffer-timeout)                600
  TCP RST/SYN in window (tcp-rst-syn-in-win)                                   5
  TCP dup of packet in Out-of-Order queue (tcp-dup-in-queue)                 617
  TCP packet failed PAWS test (tcp-paws-fail)                               1248
  IPSEC tunnel is down (ipsec-tun-down)                                        2
  Slowpath security checks failed (sp-security-failed)                      1699
  DNS Inspect id not matched (inspect-dns-id-not-matched)                      4
  FP L2 rule drop (l2_acl)                                                 15436
  Dropped pending packets in a closed socket (np-socket-closed)                2
Please let us know what reason can be there for high cpu usage by Dispatch unit under current statistics?
What else should be checked  to ensure cpu usage comes down?
Gurjit Singh
Network Engineer
Spooster IT Services.
Everyone's tags (1)
1 REPLY
Hi Gurjar,
Hi Gurjar,
r u getting the below mentioned syslog messages?
106023, 106100, 106004
TCP Out-of-Order packet buffer full:
    This counter is incremented and the packet is dropped when appliance receives an
out-of-order TCP packet on a connection and there is no buffer space to store this packet.
Typically TCP packets are put into order on connections that are inspected by the
appliance or when packets are sent to SSM for inspection. There is a default queue size
and when packets in excess of this default queue size are received they will be dropped.
Recommendations:
    On ASA platforms the queue size could be increased using queue-limit configuration
under tcp-map.
Similarly you need to check many reasons for the asp drop logs that you have captured and you need to monitor how much it is increasing and the difference.......
but 40 % CPU utilization is a okay kind of thing and you do not need to worry if that happens only during peak hours ans it is not increasing drastically more and more.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/command/reference/cmd_ref/s2.html#wp1435096
Karthik
859
