DMZ interface limitation in FWSM and ASA
Hi there!
Could anyone let me know how many interfaces can be configured as DMZ in FWSM and ASA firewalls..is there any limitation?
1 ACCEPTED SOLUTION
Super Bronze
Interface limitation depends on the device model and its license.
The most limited model is ASA5505 with Base License which only allows 2 normal Vlan interface and one restricted DMZ. With any other model you shouldnt really be running into interface limitations unless you truly have a large network.
This document lists the information related to the original ASA5500 Series
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd80285492.pdf
This document lists the information related to the ASA5500-X Series
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/at_a_glance_c45-701635.pdf
Both of the above document the maximum amount of Vlan interfaces
I am not sure if the FWSM has any licenses for the interface (Vlan) amount but I do know that its maximum limit is at around 1000 Vlan interface.
Hope this helps
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more if needed.
- Jouni
1 REPLY
Super Bronze
Hope this helps
- Jouni
114
