dmz -pix - remote lan
hello all,
i am kindly ask you for your help in a strange situation. attached you will find a layout of my network.
all networks before R2 include the interface of this router on 10.10.10.0 network is pinging with Server X.
the host on Lan 192.168.239.0/24 does not ping.
what i want to do is to access this server from all networks without a static nat on inside network.
thank you!
Hall of Fame Super Blue
Re: dmz -pix - remote lan
Does the pix have a route back to the 192.168.239.0/4 netwrok via R1.
Could you send a copy of the pix config plus a "sh ip route" from both R1 and R2.
Jon
yes,
route inside-net 192.168.239.0 255.255.255.0 192.168.40.20 1
also from host on 192.168.239.0 i can ping ip address of inside interface.
i will send also the config.
thank you
thank you Jon , i found it.
it was a ACL on R2 :)
thanks
No problem. Glad you found the solution and thanks for letting me know.
117
