DMZ Sub interfaces into sub interface
We have ASA FW 5010 in our organization and we have 4 DMZ's under the DMZ interface on ASA and all DMZ's are created on sub interfaces and assigned different VLANS on each DMZ's like
DMZ-1 = 172.20.1.x - VLAN 1000
DMZ-2 = 172.20.2.x - VLAN 1200
DMZ-3 = 172.20.3.x - VLAN 1300
DMZ-4 = 172.20.4.x - VLAN 1400
My question is:
Can we break sub interface (DMZ-4) into again another sub interface and assign another IP address like
DMZ-4 = 172.20.4.x
---------= 172.20.5.x
Means one VLAN has two IP addresses for gateway.
One thing more how many times we can break one interface into subinterfaces.
I hope my question is enough for understanding.
Saeed
Everyone's tags (3)
No, this is not a supported feature.
I think you can put 250 subinterfaces on a physical interface.
Thanks for the reply.
Can we break this feature on catalyst switches 2960 or 3560?
"Can we break this feature on catalyst switches 2960 or 3560?"
Answer is still no.
Hope that answers your question.
thanks
Rizwan Rafeek.
VIP Purple
Re: DMZ Sub interfaces into sub interface
You just want to have two IP-networks in one VLAN? If yes, that is possible on Routers and Switches with secondary IP-addresses. But the ASA doesn't support that.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Hi Saeed,
You can create sub interface for the sub interface... because virtual interfaces can be created on the physical interfaces...... But two ip segments for a single vlan is possible in L3 switches / Routers. I never tried it in firewalls....
Here is the example in L3 switch
interface Vlan100
ip address 10.0.0.4 255.255.255.0 secondary
ip address 10.2.2.4 255.255.254.0
no shut
Sorry... Small correction... You cannot create....
ASA 5510 supports max of 100 sub interfaces / vlans.....
698
