DMZ to inside and inside to Dmz
I am trying to setup a dmz to talk to my internal network and the internal network to talk to the dmz.
Any ideas
Re: DMZ to inside and inside to Dmz
Create the translation-
static (inside,intf2) 1.30.30.0 1.30.30.0 netmask 255.255.255.0
The add an ACL to restrict traffic-
access-list dmz_access_out permit udp any host yyy.yyy.yyy.9 eq 53
Then apply to the interface-
access-group dmz_access_out in interface intf2
Hope that helps
Thanks for the reply chris.
I need to allow all traffic to the internal network from the DMZ and All traffic from the DMZ to the internal network.
access-list dmz_acl permit ip 172.30.30.0 255.255.255.0 1.30.30.0 255.0.0.0
access-group dmz_acl in interface intf2
inside has default permit any so you're OK there.
167
