Does packet input ever report the wrong thing?
Hello All.
Consider these bits of configuration from my ASA:
ASA Version 9.1(3)
hostname wnsk-asa
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
object network callhost-inside
 host 10.3.2.25
object network callhost-outside
 host 209.198.173.58
object-group network EQUINOX
 network-object host 175.146.14.236
 network-object 175.77.48.96 255.255.255.224
 network-object 209.198.187.0 255.255.255.0
access-list inbound12 extended permit tcp object-group EQUINOX host 10.3.2.25 eq 3389
access-list inbound12 extended permit tcp object-group EQUINOX host 10.3.2.25 eq 5900
access-list inbound12 extended permit tcp object-group EQUINOX host 10.3.2.25 eq ftp
access-list awcc_vpn extended permit ip host 10.3.2.25 host 172.31.250.150
nat (server-lan,itrunk) source static callhost-inside callhost-inside destination static awcc awcc no-proxy-arp route-lookup
object network wnsk
 nat (server-lan,itrunk) dynamic WNSK-POOL
 nat (server-lan,itrunk) static callhost-outside
object network vpnpool
 nat (itrunk,itrunk) dynamic WNSK-POOL
access-group inbound12 in interface itrunk
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
: end
When I check my setup with packet input, I get this:
wnsk-asa# packet input itrunk tcp 209.198.187.78 22222   10.3.2.25 3389
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   10.3.2.0        255.255.255.0   server-lan
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: itrunk
input-status: up
input-line-status: up
output-interface: server-lan
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
When I actually get on the host at 209.198.187.78 and attempt to connect to port 3389 of 209.198.173.58, it works.  Packet input says it will not work.  What am I getting wrong, or is the ASA tricking me?
ERM
Bitwrangler for FirstLight Fiber Corp
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
n your packet-tracer string
In your packet-tracer string you direct the ASA to tell you about reachability of "10.3.2.25 3389". In your text you mention being able to get to "port 3389 of 209.198.173.58".
Which of those two are you trying to figure out?
1 REPLY
31
