doubt failover
hi sirs
I have a doubt. in my company there ASA5540 with SSM module is security, but can not do  failover because the other ASA does not have this module. the SSM module is not being used. I can disable the module with the command "HW-Module" shutdown. if I do, failover works?
I do not want to stop the main firewall, which contains the module SSM
1 ACCEPTED SOLUTION
Re: doubt failover
Well no, If you take a look at the show version... you will be able to see the backplane  interface and the management interface of the module  as another interface... by that, even if the module is off, the interface will show in the show version... making them no different on hardware basis, hence, failover wont work.
Bottom line, even if you turn off the module... backplane and management interfaces are added, no matter if you are using it or not... that will make failover fail...
Cheers...
Mike.
Mike
Re: doubt failover
I would think that it should work because if the module is turned-off it's not part of the working hardware obviously.... but to be on the safe side via ASDM when you configure failover... it will check the status of the peer and should tell if you if all the ''failover checks'' work fine.
Federico.
Re: doubt failover
Cheers...
Mike.
Mike
Re: doubt failover
Thiago,
There you have your answer...
I would have thought it should work, but as Maykol said... it won't (even with the module off).
Federico.
Re: doubt failover
Thank you for the explanation
I will then perform the removal of the module
thanks
Re: doubt failover
Hello Thiago
Thanks, would you pleae check this problem as solved?
Cheers.
Mike
Mike
Re: doubt failover
yes man
This resolved my problem , i've tried for evidence test , and shutdown module didn't work really.
only works when i removed it.
thanks a lot
best regards
220
