Download Speed on PIX 515E is Pretty Slow
Hello, I have a PIX 515E set up between our office switch and our Comcast Business Router and the download speeds are not as fast as they should be. We are paying for 30 down 30 up but it's more like 10 down 30 up. I plugged in a computer directly into the router and got 30/30 so I know its not a comcast issue. I think it might be the low amount of memory on the PIX because its running at 109 out of a total 128mb. The PIX has a site-to-site VPN tunnel with a remote ASA 5520 firewall. The inside/outside ports are both auto/auto. The running config is only 161 lines.
Here's some information about the PIX 515E...
Version 8.0(4)
ASDM 6.1(3)
Memory 128MB
Here is the running config..
Result of the command: "show running-config"
: Saved
PIX Version 8.0(4)
hostname --------------------
domain-name -----------------
enable password -------------------------
passwd --------------- encrypted
names
name 1.1.1.1 Data-Center-Firewall    #### Outside Address Changed
name 10.0.0.0 Data-Center-Subnet
dns-guard
interface Ethernet0
nameif inside
security-level 100
ip address 10.10.1.1 255.255.255.0 standby 10.10.1.254
interface Ethernet1
nameif outside
security-level 0
ip address 2.2.2.1 255.255.255.252   #### Outside Address Changed
interface Ethernet2
description LAN/STATE Failover Interface
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service http8080 tcp
description http8080
port-object eq 8080
object-group service DM_INLINE_TCP_1 tcp
port-object range 50000 50100
port-object eq 990
access-list outside_access_in remark ip, tcp/990
access-list outside_access_in extended permit tcp host 1.1.1.1 host 2.2.2.5 object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit icmp any any
access-list ACL-VPN extended permit ip 10.10.1.0 255.255.255.0 Data-Center-Subnet 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
failover
failover lan unit primary
failover lan interface failover Ethernet2
failover lan enable
failover key *****
failover replication http
failover mac address Ethernet0 001e.f732.008f 000d.28f9.628f
failover mac address Ethernet1 001e.f732.0090 000d.28f9.6290
failover link failover Ethernet2
failover interface ip failover 10.10.10.10 255.255.255.252 standby 10.10.10.20
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image flash:/asdm-613.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list ACL-VPN
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 2.2.2.5 10.10.1.102 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 2.2.2.2 1
route inside 10.10.0.0 255.255.255.0 10.10.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.10.0.0 255.255.255.0 inside
http 10.10.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service resetoutside
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set AES128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map MAP-VPN 1 match address ACL-VPN
crypto map MAP-VPN 1 set pfs
crypto map MAP-VPN 1 set peer Data-Center-Firewall
crypto map MAP-VPN 1 set transform-set ESP-3DES-SHA
crypto map MAP-VPN 1 set security-association lifetime seconds 28800
crypto map MAP-VPN 1 set security-association lifetime kilobytes 4608000
crypto map MAP-VPN interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
telnet 10.10.1.0 255.255.255.0 inside
telnet 10.10.0.0 255.255.255.0 inside
telnet timeout 5
ssh 10.10.0.0 255.255.255.0 inside
ssh 10.10.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
class-map class_ftp
match port tcp eq ftp-data
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
class class_ftp
  inspect ftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b795d4f5f5da3d8283d452ba857d5534
: end
1 ACCEPTED SOLUTION
Re:Download Speed on PIX 515E is Pretty Slow
Hello jack,
1. When you connect links directly to the laptops or desktops, they adjust the mtu to the best available for throughput.
Try changing the mtu on the pix to a lower value on decrements of 32 and test.
2. Try no service-policy global_policy global once. Since you mentioned download is slow.
Rgds/dp
Pls rate useful posts.
Sent from Cisco Technical Support Android App
Hi Bro
Personally, I don't think this is a Cisco FW issue. However, I stand corrected. Before we conclude anything, could you fix the Eth0 and Eth1 port speed/duplex to 100FULL. Next, could you place a laptop directly to the Eth0 interface and verify once again the download/upload speed?
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
Hi Jack,
Please check on the speed and duplex settings whether the downstream and upstream links are fine and healthy.
Check for the processes usage of the cpu of the pix.
Check on the inetrface whetehr u get any crc/input/overrun errors. Please check with the physical connectivity.
enable flowcontrol recieve on on the firewall interfaces and switch/router interfaces connected to the firewall.
Please do rate if the given information helps.
By
Karthik
Inside/outside are both set to auto/auto at
CPU is running at 2%
Process:      tmatch compile thread, PROC_PC_TOTAL: 2, MAXHOG: 8, LASTHOG: 8
LASTHOG At:   19:01:15 EST Dec 31 1992
PC:           26b616 (suspend)
Process:      tmatch compile thread, NUMHOG: 2, MAXHOG: 8, LASTHOG: 8
Traceback:    26b616  26bdb9  26ec89  1182b3
Process:      Dispatch Unit, NUMHOG: 1, MAXHOG: 5, LASTHOG: 5
LASTHOG At:   09:25:12 EDT Jul 18 2012
PC:           130114b (interrupt)
Traceback:    100178  12edd0c  9771e5  8c0e66  927164  928996  8ec3f5
              8ec7ed  79d35e  2780c3  1182b3
Process:      Unicorn Admin Handler, NUMHOG: 1, MAXHOG: 5, LASTHOG: 5
LASTHOG At:   12:27:25 EDT Jul 18 2012
Traceback:    100178  d870cb  13016b3  15cf68  e91a6f  e9118b  abfcea
              a7cb2e  a7daeb  18d800  5ae9a9  5a6aa0  5a7272  5a75e5
Process:      Unicorn Admin Handler, PROC_PC_TOTAL: 4, MAXHOG: 7, LASTHOG: 7
LASTHOG At:   12:34:10 EDT Jul 18 2012
PC:           5ae903 (suspend)
Process:      Unicorn Admin Handler, NUMHOG: 4, MAXHOG: 7, LASTHOG: 7
Traceback:    5ae903  5a6aa0  5a7272  5a75e5  5ad3d5  1182b3
Process:      Unicorn Admin Handler, PROC_PC_TOTAL: 4, MAXHOG: 5, LASTHOG: 5
LASTHOG At:   12:37:47 EDT Jul 18 2012
PC:           f4078b (suspend)
Process:      Unicorn Admin Handler, NUMHOG: 4, MAXHOG: 5, LASTHOG: 5
Traceback:    f40be2  130f41e  aab54d  aac3b0  5a6c2e  5a7272  5a75e5
              5ad3d5  1182b3
Process:      IKE Daemon, NUMHOG: 1, MAXHOG: 5, LASTHOG: 5
LASTHOG At:   23:07:40 EDT Jul 19 2012
PC:           1b6dd0 (interrupt)
Traceback:    100178  1b8a31  1baaeb  6438d7  12efc6f  64250b  653fe9
              654b78  1182b3
Process:      IKE Daemon, PROC_PC_TOTAL: 347, MAXHOG: 31, LASTHOG: 30
LASTHOG At:   16:01:55 EDT Jul 23 2012
PC:           654bab (suspend)
Process:      CTM message handler, PROC_PC_TOTAL: 346, MAXHOG: 27, LASTHOG: 27
PC:           2087ec (suspend)
Process:      IKE Daemon, NUMHOG: 693, MAXHOG: 31, LASTHOG: 27
Traceback:    1182b3
LASTHOG At:   17:23:30 EDT Jul 23 2012
PC:           130003b (interrupt)
Traceback:    100178  13008b8  f5a0cd  f5ac32  f5ae40  f60828  f617c1
              d38a0d  aab50b  aac14a  5a6c2e  5a7272  5a75e5  5ad3d5
Process:      Dispatch Unit, PROC_PC_TOTAL: 227, MAXHOG: 432, LASTHOG: 35
LASTHOG At:   17:37:03 EDT Jul 23 2012
PC:           278207 (suspend)
Process:      Dispatch Unit, NUMHOG: 227, MAXHOG: 432, LASTHOG: 35
Traceback:    278207  1182b3
Process:      Unicorn Admin Handler, PROC_PC_TOTAL: 1901, MAXHOG: 8, LASTHOG: 7
LASTHOG At:   17:44:20 EDT Jul 23 2012
PC:           118ed5 (suspend)
Process:      Unicorn Admin Handler, NUMHOG: 1901, MAXHOG: 8, LASTHOG: 7
Traceback:    118ed5  b2d032  f5a80d  f5ac0a  f5ae40  f607e5  f617c1
CPU hog threshold (msec):  5.120
Last cleared: None
Interface Ethernet0 "inside", is up, line protocol is up
  Hardware is i82559, BW 100 Mbps, DLY 100 usec
    Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
    MAC address __________, MTU 1500
    IP address 10.10.1.1, subnet mask 255.255.255.0
    60862937 packets input, 29025667892 bytes, 0 no buffer
    Received 1371 broadcasts, 0 runts, 0 giants
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 L2 decode drops
    68515603 packets output, 44084404472 bytes, 0 underruns
    0 babbles, 0 late collisions, 0 deferred
    0 lost carrier, 0 no carrier
    input queue (curr/max packets): hardware (0/1) software (0/47)
    output queue (curr/max packets): hardware (0/67) software (0/1)
  Traffic Statistics for "inside":
    60997029 packets input, 28080179952 bytes
    68553614 packets output, 43104566708 bytes
    29544 packets dropped
      1 minute input rate 63 pkts/sec,  30371 bytes/sec
      1 minute output rate 64 pkts/sec,  16557 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 91 pkts/sec,  45254 bytes/sec
      5 minute output rate 93 pkts/sec,  56181 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface Ethernet1 "outside", is up, line protocol is up
    MAC address ___________, MTU 1500
    IP address ___________, subnet mask 255.255.255.252
    67730933 packets input, 44248541375 bytes, 0 no buffer
    Received 4493 broadcasts, 0 runts, 0 giants
    0 L2 decode drops
    60418640 packets output, 29310509840 bytes, 0 underruns
    input queue (curr/max packets): hardware (0/1) software (0/39)
    output queue (curr/max packets): hardware (0/42) software (0/1)
  Traffic Statistics for "outside":
    67782987 packets input, 43276611710 bytes
    60562287 packets output, 28342787997 bytes
    206651 packets dropped
      1 minute input rate 57 pkts/sec,  14273 bytes/sec
      1 minute output rate 61 pkts/sec,  30258 bytes/sec
      5 minute input rate 89 pkts/sec,  54426 bytes/sec
      5 minute output rate 87 pkts/sec,  45115 bytes/sec
Not sure how to do that.
interface Ethernet0
speed 100
duplex full
nameif inside
security-level 100
interface Ethernet1
speed 100
duplex full
nameif outside
security-level 0
Note: Make sure you do the same for the direct attached switchports too
Hello jack,
Rgds/dp
The MTU was the problem, ran a bunch of pings with a do not fragment option until I got to 1272 so 1300 is my MTU. Speeds are closer to what they should be now. We recently switched to Comcast Business and I guess their MTU is 1300. Thanks everyone for the help!
Great to know that it was helpful.
Pls rate the post.
2491
