Dual ASA 5520's with failover
In a active/standby config, should I use a hardwired cross-connection between them or a separate switch between them. How about in a active/active config? Thanks
Re: Dual ASA 5520's with failover
According to the configuration guide, you should either use the failover cable (special cable) or the LAN.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
Hope that helps.
Use the failover cable. It was designed for a reason.
special cable was designed for PIX not for ASA.
on ASA you should do LAN based failover.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/failover.html
Dear,
Best way is to use a switch or dedicated vlan.
163
