Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Dual Home on ASA 5505
Does anyone know if you can "Dual Home" on the ASA 5505? Our current Internet connection is a 6mb pipe using 20x.x.x.x. We are installing a bigger pipe from another provider 7x.x.x.x but need to keep the "small" pipe in place as we transtition from one IP range to the other. Thus, the need to Dual Home.
Thanks Mucho!!
1 ACCEPTED SOLUTION
Re: Dual Home on ASA 5505
The ASA does not support dual homing if both ISP links are active at the same time. You can configure a backup scenario like this tough:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
If you have a router available, you could terminate the links on the router and do PBR on it.
Farrukh
Farrukh
Farrukh, thanks for your insight. We will pursue as you suggested.
Thanks Mucho!!
862
