Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DynDNS on 1800 not working after following Cisco guide or SDM?
I've setup an account with DynDNS and I've tried to configure my 1800 router to update this host record, either via CLI or through the use of the SDM, yet neither method seems to be working. I've included my dyndns config for your review;
ip ddns update method sdm_ddns1
HTTP
add htp://mccwindsor3:mccwindsorxxxxx@members.dyndns.org/nic/update?system=dyndns&hostname/nic/update?system=dyndns&hostname</A>=<h>&myip=<a>
remove htp://mccwindsor3:mccwindsorxxxxx@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interval maximum 28 0 0 0
and under my dialer interface i've got;
ip ddns update hostname mccwindsor3.dyndns.org
ip ddns update sdm_ddns1
I've enabled ddns debugs, yet I see nothing in the logs, and the hostname never updates with the proper address. I can ping internet hosts by name from the console of the router with no problems and I've even gone so far as to add;
ip inspect default tcp router-traffic
to the inspect applied to the outbound of my dialer and still nothing. Any ideas? I've set this up on other routers with no problem in the past. Thanks
J
EDIT, sorry for the underlines, not sure how to remove them :(
Re: DynDNS on 1800 not working after following Cisco guide or SD
Hi Jason
I think the problem is just your spelling.
Change htp:// to http://
I have the same config and it works ok.
Cheers
Sorry, I was trying to get this forum to remove the blue underlining of links, so I tried to change the HTTP to HTP, the real config does say HTTP not htp. Any other ideas? Thanks
J
Just make sure you have "ip domain lookup" or "ip domain-lookup" (which it should be by default). If you don't have it, it won't be able to translate the URL to IP.
Then make sure you have "ip name-server" configured eg "ip name-server 4.2.2.2" (which is a free public DNS server). I have my ISPs DNS servers configured and the one above.
640
