Easy asa management question
Hi All,
What is the application you can use for managing multiple asa firwall rule bases?
thanks
1 ACCEPTED SOLUTION
Re: Easy asa management question
The Cisco Security Manager application can manage multiple firewalls and allows a single rule to be applied to hundreds of devices simultaneously. Check it out at:
http://www.cisco.com/en/US/products/ps6498/index.html
SSH, Telnet or ASDM. ASDM is stored on the firewall, and you get to it by https://
There's no application that I'm aware of that will allow you to connect to multiple firewalls and manage all of the rulesets via a centralized management console.
HTH,
John
HTH, John *** Please rate all useful posts ***
thats the one
Thank you
Mick
97
