04-04-2012 10:34 AM - edited 03-11-2019 03:50 PM
I have two ASA both are remote sites which currently has a leased line. Static router are placed on the ASA to route traffic via the leased line. I want to be able to introduce a VPN failover connection between the sites and run EIGRP over the VPN tunnel.
I know its possible to run EIGRP using a GRE tunnel on a router, but I can't seem to find any information in terms of running EIGRP (GRE tunnel) with only ASA as the only Cisco device on each remote site.
Has this been done before?
04-04-2012 10:52 AM
On the ASA you can't set up a GRE tunnel and as far as I remember EIGRP can't pass over an IPSEC tunnel.
04-04-2012 01:27 PM
Thank you, therefore could I use OSPF over the VPN tunnel and the leased line, then if the leased goes down OSPF will route traffic via the VPN tunnel?
04-04-2012 03:08 PM
you can use OSPF over VPN using unicast instead of multicast. If OSPF is running you can have multiple paths to a destination and the traffic will use both paths when active or you can tell which path is the desired. If one goes down it will use the one active.
