Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Enable ICMP response on OUTSIDE interface based on DNS in ASA
Hello All,
I have what I'm sure is a simple question, but is frustrating me.  I'd like to enable ICMP response on the outside interface of my ASA's to respond to ICMP traffic that is sent from a specific DNS address (an external monitoring service).  Any thoughts on how best to accomplish this?  Thanks in advance.
Issue is the routable IP will change regularly, but the DNS address will remain the same.  A pool of IPs basically.  Thanks in advance,
1 ACCEPTED SOLUTION
Hello Ronan,
So only ICMP responsed from outside from the Domain-Name of that host
Nah, I do not see this being possible on the ASA at the moment, you will need to use the IP pool as the only method to be restrictive.
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Silver
Well ICMP is always allowed but ISP normally have what is called stick DNS, so my question would be, do you want to restric IP address from reaching the ASA via ICMP and only allow the DNS hosting site
Value our effort and rate the assistance!
Hello Ronan,
Jcarvaja
Julio Carvajal
Silver
Need help????
Community Member
My sincere apologies for not replying sooner.  I've been away and unable to respond quicker.  Thank you very much for your quick answer.  Looks like IP Pool is the way to go in this case.  Once again, thank you.
409
