enabling a third interface
question is more cosmetic I guess but I'm trying to name a third interface and I get an error stating you cannot have more than 2 named non-management interfaces on your system. My other ASAs can do this with the excpetion of this one. We are all on 7.2(2) software. Any ideas?
1 ACCEPTED SOLUTION
Silver
Re: enabling a third interface
Your firewall might be running in transparent mode. In this mode, you can only have 2 non-management interfaces.
ASA# show firewall
Firewall mode: Transparent
If you dont want your firewall in Transparent mode, you can change it to router mode using following command-
ASA(config)# no firewall transparent
Hope that helps.
Vibhor.
Silver
ASA# show firewall
Hope that helps.
Vibhor.
That was it.
Thanks.
169
