Enabling failover on ASA5520 VLAN interfaces
I want to set up my VLAN interfaces for failover monitoring. These VLAN interfaces are off the inside interface. The inside interface is being monitored. Currently, by default the VLAN interfaces are not being monitored. These VLAN interfaces are already configured with a standby address.
What is the best approach to configuring monitoring on them?
Do I just simply configure a failover interface IP address on the VLAN interface using a subnet different from my other monitored interfaces?
Or is it completely not necessary to enable failover on the VLAN's since the inside is already being monitored. Cannot find a yes/no answer in any texts.
  • Firewalling
1 REPLY
Re: Enabling failover on ASA5520 VLAN interfaces
Hi, If you look at this link diagram you have inside side , outside switch , and the pair of ASA in the middle one active and other in standby, both interfaces are being monitored.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
The answer to your question is yes, you need to configured for each vlan subinterface or interface on the ASA a failover to have the interface monitored.
Example:
ASA_Primary: outside ip 172.16.1.1
ASA_Primary: inside_IP 10.20.20.1
ASA_Secondary: outside IP 172.16.1.2
ASA_Secondary: outside ip 10.20.20.2
interface Ethernet0/0
description outside
nameif outside
security-level 0
ip address 172.16.1.1 255.255.255.0 standby 172.16.1.2
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.20.20.1 255.255.255.0 standby 10.20.20.2
interface Ethernet0/2
description LAN Failover Interface
interface Management0/0
description STATE Failover Interface
management-only
same principle above applies for asa subinterfaces if u are doing dot1q trunking.
failover
failover lan unit primary
failover lan interface failover Ethernet0/2
failover link state Management0/0
failover interface ip failover 10.1.0.1 255.255.255.0 standby 10.1.0.2
failover interface ip state 10.0.0.1 255.255.255.0 standby 10.0.0.2
PLS rate any helpful posts
361
