Err code : 106021
hi all
I am getting error code message (106021)generating about 1GB of logg message daily on my firewall to my sylog server , the address in this error message is invalid source address which is not configured are connected to my internal lan of pix firewall. i have network of 172.16.x.x but my error message comes in range of 10.0.0.1 .
Oct 09 2009 08:36:54: %PIX-1-106021: Deny UDP reverse path check from 172.21.19.
201 to 128.9.0.107 on interface inside
201 to 192.33.4.12 on interface inside
Oct 09 2009 08:36:58: %PIX-1-106021: Deny UDP reverse path check from 172.21.19.
201 to 128.8.10.90 on interface inside
201 to 192.203.230.10 on interface inside
Oct 09 2009 08:37:01: %PIX-1-106021: Deny UDP reverse path check from 172.21.18.
92 to 10.0.0.1 on interface inside
Oct 09 2009 08:37:02: %PIX-1-106021: Deny UDP reverse path check from 172.21.18.
kindly let me know wht to be done to reduce logg message to be generated
1 REPLY
Re: Err code : 106021
Deny ... reverse path check means that the Pix is receiving packets from an address for which the Pix has a route that points to a different interface.
In each of the examples you give, the source is 172.21.x.x, so the Pix is receiving packets from 172.21.x.x on the inside interface but it does not have a route to these addresses towards the inside interface.
So either you should add a route (if these are legitimate addresses) or find out who/what is sending these packets.
BTW if you just want to stop the messages from being logged you can configure:
no logging message 106021
Or better is to rate-limit it, e.g.
logging rate-limit 1 60 message 106021
This will reduce the amount of 106021 messages to 1 per 60 seconds.
hth
herbert
992
