Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Silver
Error, please help!!!!
whenever I do "sh run", I get nothing.
If I do "show start", I get the following
error:
C2621#sh start
Using 10783 out of 29688 bytes, uncompressed size = 25550 bytes
%No memory availableCouldn't uncompress config (-1)
%Error opening nvram:/startup-config (Uncompression Failed)
Basically, I can not see the running
config and start-up configuration unless
I reboot the router (IOS with Firewall
Feature set). Anyone know why?
I delete the nvram:private-config but it does not help. Can anyone help?
C2621#sh ver
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(24a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 18-Dec-07 19:01 by stshen
Image text-base: 0x80008098, data-base: 0x81A1E370
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
C2621 uptime is 18 hours, 17 minutes
System restarted at 02:45:35 UTC Sun Feb 10 2008
System image file is "flash:c2600-ik9o3s3-mz.123-24a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 2621 (MPC860) processor (revision 0x102) with 59392K/6144K bytes of memory.
Processor board ID JAD12345X7 (123456787)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
3 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
C2621#
C2621#
C2621#sh run
C2621#
C2621#
C2621#sh start
C2621#wr mem
startup-config file open failed (Not enough space)
C2621#
C2621#dir flash:
Directory of flash:/
1 -rw- 16077544 Mar 1 1993 00:04:41 +00:00 c2600-ik9o3s3-mz.123-24a.bin
16252924 bytes total (175316 bytes free)
C2621#dir nvram:
Directory of nvram:/
13 -rw- 10783 <no date> startup-config
14 ---- 4275 <no date> private-config
1 -rw- 0 <no date> ifIndex-table
2 ---- 13 <no date> persistent-data
29688 bytes total (12530 bytes free)
C2621#
Re: Error, please help!!!!
when this problem started, after IOS upgradation?
regards
skrao
Silver
It just started recently. NO IOS upgrade.
CCIE Security
what about switch functionality. It is clear that show start and show run commands are not displaying configuration.
what about other commands and switch functionality.
regards
skrao
Silver
The router is working and passing traffics
just fine. Other commands such as "show
interface" and "reload" work. After
about 2 hours, I can not even telnet/ssh
into the router anymore and it required
a power OFF/ON.
CCIE Security
Are you able to capture the log/console messages during problem.
Please post your tech support file.
If possible try with different IOS image even the current IOS worked fine for quiet some time.
regards
skrao
429
