Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Error when using wr mem
Hi everyone,
I got a strange problem, on my FWSM, when i use the command wr mem i get a error, any one seen this befor ??
ipmsap/act# wr mem
Building configuration...
Cryptochecksum: xxx
%Error copying flash:/startup-config (Cannot overwrite image (asdm) file with ascii text file.)
Error executing command
[FAILED]
ipmsap/act#
The configuration i don just after session slot X processor 1
Cheers
Peter
Re: Error when using wr mem
is this in failover ?
if yes,
issue a wr erase first and afterwards " wr mem "
please rate if this helps
Sushil
Yes the firewall is one part of failover setup, but it is the primary in the failover,
the error was first seen after a password recovery attemt.
cheers
Peter
please make the other unit primary,do a wr erase on this one.one the config. is replicated,then do a " wr mem " .
hth
Sushil
Cisco TAC
402
