extend SSH remote session to prevent quick timeout
Hvaing problem on my Apps team keep on complaint their remote SSH session keep on timeout.
Just wondering anything i can do in order to extend their SSH remote session to their Oracle application server 10g.
thanks
Noel
Hi Noel,
Is this SSH session passing throught the ASA to the oracle?
MKD
Hi Mohammed,
Yes, traffic logically go though Firewall, firewall as the gateway.
thanks
Hi Noel,
Are you sure that the ASA drop the ssh session? how? any logs?
Is the session drop when no traffic? or what?
MKD
Hi Noel,
Try to change the tcp timeout global configuration which will resolve your ssh timeout issue. The default timeout is 30 min.
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
Plz rate if its helpful.
MKD
Gold
what type of SSH software are they using ? it could be that the software is not sending keepalive packets.
If it is possible then you can set the software to send "keep alive" packets to keep the tunnel active even if the user does nothing for a while.
fx in putty this is done under connection and there you have
enable tcp keepalive
and
sending of null packets to keep session active
set this number to fx 50 ie 50 seconds between null packets to be sent within the keepalive.
Good luck
Hope This Helps
1058
