Fail to Wire in Cisco Pix 525 (on Transparent Firewall mode)??
Is possible configure fail to wire in a PIX working on Transparent firewall mode, to allow pass all the traffic in case of shutdown o reset the PIX?
Best regards.
Everyone's tags (2)
Re: Fail to Wire in Cisco Pix 525 (on Transparent Firewall mode)
Yes, failover is possible for PIX 525 in transparent mode.
For Active/Standby failover, here is the configuration guide:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/failover.html#wp1058096
Hope that helps.
I want say, with a single PIX, if I turn it off or restart it, if PIX allows traffic to pass through it like a cable
OK, thanks for the clarification.
The answer is no, if you reset the PIX firewall or turn it off, it will not pass any traffic at all.
1177
