Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Failed to use own CA and sub-CA
Hello everybody,
I am having an issue with using my own CA.
I have the certificates from the CA and sub-CA at hand in all kinds of formats (.der, .pem, .p12)
  • I've created the trustpoint (MAINCA) in ASA via CLI and provided details (subject-name, fqdn, enrollment terminal, NO SERIAL)
  • I've generated the CSR on the ASA from CLI with no problems (enroll the trustpoint).
  • I've saved the CLI output of the CSR to a file
  • I let the sub-CA process the CSR - and the CA has processed it as well just to give it a try
  • I've the Certificate ready formated as .der and .pem
As mentioned in Cisco Documentation I now have to authenticate the trustpoint with
crypto ca authenticate MAINCA
where the trustpoint-name is the same as the one from creating a trustpoint just a little earlier.
  • I can paste the characters from the .pem-file of either, the CA or the sub-CA with no problem at all
  • I finish as asked with quit
  • I get the info that certificate has a fingerprint - ok - and if I would like to accept the certificate - yes is what I entered.
The process is, however, aborted with:
% Error in saving certificate: status = FAIL
I started a debug as well - but I don't get it
CRYPTO_PKI: can not set ca cert object (0x701)
CRYPTO_PKI: status = 65535: failed to process RA certificate
CRYPTO_PKI: Cleaned PKI cache successfully
CRYPTO_PKI: Starting to build the PKI cache
CRYPTO_PKI: Failed to retrieve router cert
CRYPTO_PKI: Failed to cache certificate chain for the trustpoint MAINCA or none available
CRYPTO_PKI: Failed to retrieve trusted issuers list or no trustpoint configured
Can somebody clear the sky, please?
Everyone's tags (3)
AFAIK the ASA does not handle CA hierarchy. You can use the sub-CA in your trustpoint. You may create another trustpoint for the root CA but it's not necessary.
Community Member
I'm having the same issue.
Did you find a way to load your Certs?
Were they using SHA256 by any chance?
