Failover FWSM Primary
I have a FWSM in Active/standby mode. My primary failed and i got a replacement. At present my standby FWSM is active and Network is running fine, I want to insert the new FWSM in the chasis, once it is inserted both will be active because there is no failover configured on the new FWSM. Now to configure the failover, i have to execute the below commands please correct me if i m wrong????? But i m afraid that after executing the commands the New FWSM will become active and it will start syncing his empty configuration to secondary and all the actual configuration will be wiped out.
Please anybody can confirm me the perfect procedure when the priamry fails and we are trying to replace the faulty FWSM
failover lan unit primary------> I hope this command will make the new FWSM active with empty configs and it will wipe out the actual working configs on the secondary FWSM
failover lan interface faillink Vlan11
failover link statelink Vlan16
failover interface ip faillink 172.24.11.1 255.255.255.252 standby 172.24.11.2
failover interface ip statelink 172.24.16.1 255.255.255.252 standby 172.24.16.2
failover
1 ACCEPTED SOLUTION
Re: Failover FWSM Primary
That is correct, you should use the same version for a long term production!
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Estela,
So the actual active FWSM is the secondary device on the HA cluster.
Now you will deploy the new FWSM and you want him to be the stand-by device eventhough he is the primary as he does not have anything configured.
So after you configured this:
failover
The active unit ( secondary in this scenario) will send his configuration file to the stand-by)
Remember failover replication is from active to secondary not from primary to secondary
Julio
Do rate helpful posts!!
Hi Matthew
Please see the following link:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a0080531753.shtml
Hope this helps.....
Craig
Dear Julio,
Remember failover replication is from active to secondary not from primary to secondary----
yes this is my question that  when i will insert the new FWSM both will be active the new fwsm and the existing secondary becz they both are not syncing together becz of no failover configuration,so after configuring failover so who will takerover whom???
The commands what i showed in above are perfect for the failover configuration to sync on the new FWSM which will configured as a primary unit.
Hello Estela,
Yeap, Failover replication  is from active to standby, so on the new device you can configure the command no failover active.
You will not have any problems as you have already setup a device as the active one...
Julio
Dear Julio,
So all together the commands for the failover are:
failover configuration on New FWSM which will be primary unit
no failover active-------This commad will prevent new FWSM to become active and to replicate his empty configs to actual configs of secondary.
failover
Hello Estela,
That is correct!
Hello Julio,
faillover can  work with difference in minor version for Example 3.2(22) in primary and 3.2(5) in secondary and also minor difference in asdm images.
The two units in a failover configuration must be  in the operational modes (routed or transparent, single or multiple  context). They must have the same major (first number) and minor (second  number) software version, but you can use different versions of the  software within an upgrade process.
In this case they will share 3.2 so in fact they will share the major an minor versions so you will be okay. eventough is recommended to upgarde the other one so they match the exact version.
So it would work!
Hello Julio,
what you have wrote above this is what i have read in configuration guide but still these words are not clear for me,
I hope what the guide trying to explain is:
If i  have a primary and secondary FWSM with 3.2(5) and If suppose i upgrade secondary from 3.2 (5) to 3.2 (19)  the failover will be active untill and unless the secondary FWSM reboots and 3.2(19) comes in action.Once i reboot secondary the failover will break and both will be Active/Active.
So the difference in minor and major will not work.
Hello Estela,
Nop, all the way around.
Take as an example this ( applies to both ASA's and FWSM)
Performing Zero Downtime Upgrades for Failover Pairs
The two units in a failover configuration should have the same major  (first number) and minor (second number) software version. However, you  do not need to maintain version parity on the units during the upgrade  process; you can have different versions on the software running on each  unit and still maintain failover support. To ensure long-term  compatibility and stability, we recommend upgrading both units to the  same version as soon as possible.
Table 43-1     Zero-Downtime Upgrade Support
Type of Upgrade
Support
Maintenance Release
You can upgrade from any maintenance release to any other maintenance release within a minor release.
For example, you can upgrade from 7.0(1) to 7.0(4) without first installing the maintenance releases in between.
Minor Release
You can upgrade from a minor release to the next minor release. You cannot skip a minor release.
For example, you can upgrade from 7.0 to 7.1. Upgrading from 7.0  directly to 7.2 is not supported for zero-downtime upgrades; you must  first upgrade to 7.1.
Major Release
You can upgrade from the last minor release of the previous version to the next major release.
For example, you can upgrade from 7.9 to 8.0, assuming that 7.9 is the last minor version in the 7.x release.
Hope this helps!
Do rate all the helpful post...
Julio
Dear Julio,
I can't understand the below lines in cisco config guide:
So i will reach to final answer that if FWSM have difference in minor version they can't work in failover for long term running production.
Please correct me if i m wrong
Hello Estela,
I mean you can have different versions on the software ( 3.2 (5) to 3.2 (19) ) while you do the upgrade, but I mean if you can have them on the same version as the Firewall device is expected to work why you should not have it like that for a long term running production. Do you understand what I mean?
Julio
Hello Julio,
As per your previous mail ,
  • As per cisco statements while only during upgrade but firewall is not aware whether we are doing upgrade or it is for long term production.???? As per logic we can have different minor version
BUT
  • Cisco recommends only during the upgrade and not for the long term production, So the conclusion is we can keep with differnet minor version but better not to keep as per cisco recommendation.
Julio
1304
