Failover link in a C65K VSS with ASA-SM
Just experienced a coombined tcp flood/ udp flood attack, which caused both ASAs to go active :-(
Active:
01:56:05 ASA-SM1 : %ASA-1-105043: (Primary) Failover interface failed
01:56:09 ASA-SM1 : %ASA-1-105042: (Primary) Failover interface OK
01:56:32 ASA-SM1 : %ASA-1-103001: (Primary) No response from other firewall (reason code = 3).
01:56:47 ASA-SM1 : %ASA-1-103001: (Primary) No response from other firewall (reason code = 4).
The standby ASA said ' failover off' but a reload of the standby fixed the dual active problem:
Standby:
ASA-SM1# sh failo
Failover Off
Failover unit Secondary
Failover LAN Interface: folink Vlan998 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
ASA-SM1# sh failo state
                    State          Last Failure Reason      Date/Time
This host  -   Secondary
                     Disabled       None
Other host -   Primary
                    Not Detected   Comm Failure      01:55:59
'Service-policy in' on the uplink interface (was 512/10 before):
embryonic-conn-max 256 per-client-embryonic-max 5
Questions:
1. possible causes for the com  failure (memory exhaust ?) Any good commands for checking ?
2. The failover link:
In an ASA appliance setup it is recomended to etasblish a dedicated physical failover link between til ASAs - What about ASA-SM in a VSS setup - does it make sense to establish a f.ex physical 1G link for failover, and if yes: won't there be a loop issue with this and the fo vlan on the VSL link ?
3. What is "interface policy 1" in the 'sh failo' command output ?
Jesper
  • Firewalling
266
