Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
failover on cisco ASA
Hi all
Is it possible to have failover set up over a routed connection? or do they have ot be back to back?
Many thanks
Carl
Community Member
Re: failover on cisco ASA
Yes it is possible but connectivity loss would cause failover,
Community Member
do many people do this kind of thing?
Would it just route to the secondary address ?
Silver
You can't have failover over a routed network unless the two failover interfaces still appeard L2 adjacent (same subnet).
If you are looking to place your firewalls in different physical locations this is possible but you may need to tweak your failover timers as latency across the cloud/WAN link could cause a failover event or put your firewalls into an active/active state.
208
