Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
failover using management interface on asa
hi all i am trying to setup asa failover using the management interface.
asa1
int e0/0
nameif inside
ip add 10.1.1.1 255.255.255.0 standy 10.1.1.2
no sh
int e0/1
nameif outside
ip add 1.1.1.1 255.255.255.0 standy 1.1.1.2
no sh
int m0/0
no sh
no management-only
int m0/0.1
no sh
vlan 30
no management-only
failover
failover lan unit primary
failover lan interface failover m0/0.1
failover interface ip failover 172.16.1.1 255.255.255.0 standby 172.16.1.2
failover key cisco
failover link failover m0/0.1
asa2
int m0/0
no sh
no management-only
int m0/0.1
no sh
vlan 30
no management-only
failover
failover lan unit secondary
failover key cisco
the asa 's are not getting failover messages from each other.
no response from mate
finally both the asa's are becoming active.
is failover not suppose to run on the management interface even if i have made it a data interface and using it dedicately for failover.
can someone pls help me on this.,
waiting for reply.
regards
sebastan
Re: failover using management interface on asa
Hi sebastan,
Management interface should not be used for the failover feature.
Infact, It will not allow the traffic to pass through it. we can use this interface for managing the device over the network.
Use any dedicated ethernet port.
Hope it helps.
--Jaffer
We are using management interface as failover link and it's working fine. The only thing is that it's only 100MB connection comapre to all GIG interfaces.
1216
