Firewall Active/Standby connection to Dual Core Inside network
I have dual core L3 Switches (4503-E) in LAN. I want to connected this Core network as Inside to Active/Failover setup. Then to connect Firewall cluster to internet through a 2821 router
Can anyboby elaborate what is the best way to achieve this. I want to do NAT in firewalls. I have only 6 public IP addresses for LAN segent.I want to eliminate single point of failure for connection from dual core to firewall cluster
regards,
Waruna
1 REPLY
Re: Firewall Active/Standby connection to Dual Core Inside netwo
You need inter chassis active/standby failover.
You can do HSRP on the inside and outside vlans on the MSFC.
Pls. read here:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/fail_f.html#wp1142744
117
