Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Firewall ASA 5505 (Transparent) - Filter with hostname
I have a question about filtering with Asa 5505. Customer asking me to configure the possibility to filter traffic between inside and outside interface using hostname of PC instead of IP. Is it possible ? Using inspection ? Is there an alternative ?
Other possibility is to use Mac Filtering, but I don't see the option in the firewell configuration.
Thanks in advance,
Benoit
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hello Benoit,
It is possible on ASA version 8.4.2. You can find more inforrmation here:
https://supportforums.cisco.com/docs/DOC-17014
Mike
Mike
Hello Benoit,
Mike
Mike
Thanks Mike.
It work's fine.
1313
