Firewall Cisco ASA 5505 new interface license problem
I have one ASA 5505 with a Base License
The problem is when i want to use a new named interface the system says "With current License maximum number of named interfaces allowed is 3. Name cannot be set for this interface"
And the question is if with this base license the interface cannot be used or only cannot be named?
here the output of my firewall:
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0    : address is e02f.6de6.7843, irq 11
1: Ext: Ethernet0/0         : address is e02f.6de6.783b, irq 255
2: Ext: Ethernet0/1         : address is e02f.6de6.783c, irq 255
3: Ext: Ethernet0/2         : address is e02f.6de6.783d, irq 255
4: Ext: Ethernet0/3         : address is e02f.6de6.783e, irq 255
5: Ext: Ethernet0/4         : address is e02f.6de6.783f, irq 255
6: Ext: Ethernet0/5         : address is e02f.6de6.7840, irq 255
7: Ext: Ethernet0/6         : address is e02f.6de6.7841, irq 255
8: Ext: Ethernet0/7         : address is e02f.6de6.7842, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 3, DMZ Restricted
Inside Hosts                   : Unlimited
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 10
Dual ISPs                      : Disabled
VLAN Trunk Ports               : 0
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
2 ACCEPTED SOLUTIONS
Super Bronze
Re: Firewall Cisco ASA 5505 new interface license problem
The ASA5505 has with Base License the limitation of 3 Vlan interface of which 1 is also limited in access (shown by the above output mentioning DMZ Restricted)
For an interface on the ASA to operate it must have a name with the command "nameif"
If you already have 3 Vlan interfaces in use then with this license you wont be able to configure 4th Vlan interface without getting a license that supports more interfaces. I guess that would be the Security Plus license.
I know that this has come as a surprise to several users that have posted here on the forums. I too think that its a needles "feature" in the ASA to limit the use of the device in such a way.
- Jouni
Did you ever get this
Did you ever get this upgraded? How much did it cost?
Super Bronze
- Jouni
Hi JouniForss
Thanks for your reply, i will make an upgrade on the Firewall!!
Hi, the upgrade was using a
Hi, the upgrade was using a cisco provider under contract, for that reason the upgrade was done without cost for the company.
756
