Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Firewall conf issue........
Below is Firewall / Switch and my router configurations,
from firewall i am able to ping my LAN pc 172.22.0.10 / 172.22.1.10 and outside ISP 172.23.43.33 and
172.23.43.13 but from my PC unable to ping that out IP's ...................pls. suggest.....
Firewall Configuration
PRIMFW# sh run
: Saved
ASA Version 8.4(2)
hostname SPANCO-PRIM
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.10.10.2 255.255.255.0 standby 10.10.10.3
interface Ethernet0/1
no nameif
security-level 0
no ip address
interface Ethernet0/1.101
description INSIDE1
vlan 101
nameif INSIDE1
security-level 90
ip address 172.22.0.2 255.255.255.0 standby 172.22.0.3
interface Ethernet0/1.102
description INSIDE2
vlan 102
nameif INSIDE2
security-level 80
ip address 172.22.1.2 255.255.255.0 standby 172.22.1.3
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
description LAN Failover Interface
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
clock timezone AST 3
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq www
port-object eq pop3
port-object eq smtp
object-group-search access-control
access-list global_mpc remark ALL TRAFFIC
access-list global_mpc extended permit tcp any any object-group DM_INLINE_TCP_1
pager lines 24
logging asdm informational
mtu outside 1500
mtu INSIDE1 1500
mtu INSIDE2 1500
mtu management 1500
failover
failover lan unit primary
failover lan interface FAILOVER Ethernet0/3
failover replication http
failover interface ip FAILOVER 192.168.3.1 255.255.255.0 standby 192.168.3.2
monitor-interface INSIDE1
monitor-interface INSIDE2
icmp unreachable rate-limit 1 burst-size 1
asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no user-identity enable
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
authentication crack
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption des-sha1
webvpn
username sanjeev password UzLK4/8fy0bhw2Nl encrypted privilege 1
username cisco password 3USUcOPFUiMCO4Jk encrypted
class-map global-class
match access-list global_mpc
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class global-class
  csc fail-open
service-policy global_policy global
prompt hostname context
service call-home
call-home reporting anonymous
call-home
contact-email-addr pradeepan.s@redingtongulf.com
profile CiscoTAC-1
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:b9d56036aaf4b6dafdf3764946e808f7
: end
SWITCH Configuration
Switch#sh run
Building configuration...
Current configuration : 4586 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip routing
crypto pki trustpoint TP-self-signed-1213331968
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1213331968
revocation-check none
rsakeypair TP-self-signed-1213331968
crypto pki certificate chain TP-self-signed-1213331968
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323133 33333139 3638301E 170D3933 30333031 30303031
  31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32313333
  33313936 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C09B 76A54237 9C118C90 E2A12B04 7731EE8C 4EE2136F 93A75202 9BAA7019
  5B735B3C A1CBE60E 431EE7F6 828463A7 797124C3 17ABDB6E 331159B2 34C251E7
  07EB43F8 E801EE18 AE19D358 7B54269B D65B6D51 89483AC0 6BE1F39F CDE026EF
  92DAC152 4D3F817C D8EBA4F9 C7C412FD 73536446 30AA3BBA 806BFF04 2BF0D997
  4C170203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07537769 7463682E 301F0603 551D2304 18301680 14E57573
  42C453D9 5539DB26 670C3009 EE0DF0C9 C1301D06 03551D0E 04160414 E5757342
  C453D955 39DB2667 0C3009EE 0DF0C9C1 300D0609 2A864886 F70D0101 04050003
  81810061 7D3E4954 4DE7724B 37FC4D4E 4AA11BEF 54A0F141 4DE49BEB 3E36CF14
  B6B30807 F1E8D532 654E6FE1 0422B7D5 4E5FE5D3 C93599D6 053CA340 798CC46F
  8170A73A 8015EF02 74E4925F 9EFB5D13 44E109D6 522EB4F9 C297C317 99FB8DF9
  35B9B39B 130D7017 CA222114 4C34C7EB ACB32392 2D5DE43A E31B1A4C 54396B30 7EE6F9
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
switchport access vlan 101
switchport mode access
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
switchport access vlan 102
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
switchport trunk allowed vlan 101,102
switchport mode trunk
switchport nonegotiate
spanning-tree portfast
interface GigabitEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address 10.10.50.1 255.255.255.0
interface Vlan101
ip address 172.22.0.1 255.255.255.0
interface Vlan102
ip address 172.22.1.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.22.0.2
ip route 0.0.0.0 0.0.0.0 172.22.1.2
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
login
line vty 5 15
login
end
ROUTER Configuration
Core_2RTR#sh run
Current configuration : 1679 bytes
! Last configuration change at 20:04:49 UTC Wed Jun 6 2012
version 15.1
hostname Spanco_Core_2
boot-start-marker
boot-end-marker
enable password spanco@987
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid C3900-SPE150/K9 sn FOC15324QJF
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description *** Spanco Airtel Core Connectivity ***
ip address 172.23.43.34 255.255.255.252
duplex full
speed 100
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
ip address 172.23.43.14 255.255.255.252
duplex auto
speed auto
router ospf 30
network 10.10.10.0 0.0.0.255 area 10
network 172.22.0.0 0.0.0.255 area 10
network 172.23.43.12 0.0.0.3 area 10
network 172.23.43.32 0.0.0.3 area 10
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.16.71
ip route 172.22.0.0 255.255.255.0 GigabitEthernet0/1
no cdp run
snmp-server community public RO
snmp-server location SPANCO_GEMI
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 111A09041911042C5D727C
login
transport input all
scheduler allocate 20000 1000
end
You can configure PAT on the firewall as the router doesn't have route back to your internal networks.
nat (INSIDE1) 1 172.22.0.0 255.255.255.0
nat (INSIDE2) 1 172.22.1.0 255.255.255.0
global (outside) 1 interface
Also enable icmp inspection on the firewall:
   inspect icmp
Community Member
HI Jen,
Thanks as usual for your kind support.
ASA Version is 8.4(2) and i don't see global command...on it.
Reg
Sanjeev
Red
Hi Sanjeev,
what Jennifer suggested are these commands in 8.4.2:
object network obj-172.22.0.0
subnet 172.22.0.0 255.255.255.0
nat (inside,outside) dynamic interface
object network obj-172.22.1.0
   subnet 172.22.1.0 255.255.255.0
   inspect icmp
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
To be exact, it should be:
nat (INSIDE1,outside) dynamic interface
   nat (INSIDE2,outside) dynamic interface
268
