Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Firewall Configuration Issue
i am having some issue while configuring PIX firewall in my network.
Please find the network digram for your refernce abt the setup.
As per diagram i am able to reach the firewall using inside interface ip address from remote end Lan.
but there is no traffic passing between outside to inside even if i kept permit ip any any ACL rule.
Can some one send me the basic configuration as per the network diagram.
It will be great help for me.
Re: Firewall Configuration Issue
You forgot to attach (I think).
Also post your sanitized configuration.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009402f.shtml
Farrukh
Community Member
Thanks for your quick reply,
apology for missing the configuration.
Please find the config & network diagram as attachment.
correct me if i am wrong at any where.
My requirement is outside lan has to access remote server through inside interface with out any nat.
Can you mention any SPECIFIC flow you are trying to test?
e.g. telnet x.x.x.x port
Also your default route statement seems to be wrong:
route inside 0.0.0.0 0.0.0.0 10.62.249.254 1
The interface you mention is 'inside' but the next-hop is actually the FW's outside interface IP??
It should be the following I guess:
route inside 0.0.0.0 0.0.0.0 10.62.248.XX
Also is your inside interface mask correct? Is it supposed to be /27?
Farrukh
Community Member
check your route command, it should be
route inside 10.62.242.0 255.255.255.0 10.62.248.62
also if you have done any Natting, you have to create a NAT exempt rule for the network range you dont want to b Natted.
Let me know for any help you require
119
